95 SL2 not shifting
Old Jul 26, 2008 | 08:34 PM
aw1563t's Avatar
I have a 1995 SL2 with 168,000 & automatic transmission. The car starts off in high gear(high rpms, takes a long time to come up to highway speed). When up to speed runs fine but will not down shift manually & the check engine light has come on. Filter & fluid have been changed. Thanks
Old Jul 27, 2008 | 10:25 AM
VALVE body?Edited by: sw2cam
Old Jul 29, 2008 | 08:35 PM
TheEngineer's Avatar
^^that would be my guess as well
Old Jul 29, 2008 | 10:01 PM
What are the SES codes?
Old Aug 1, 2008 | 10:42 AM
Low Saturn's Avatar
How to display codes
What they meanEdited by: Low Saturn
Old Aug 14, 2008 | 09:44 AM
Notahonda's Avatar
I''d also check the TSS (turbine shaft speed) sensor. It''s located on the front of the transmission near the filter. Also check the VSS (vehicle speed sensor) located on the rear of the transmission by the axle shaft. Those two sensor will also cause shifting problems.
Old Aug 14, 2008 | 09:54 AM
Low Saturn's Avatar
The car will also tell you what''s wrong if you check to see why the SES light is on.
Old Aug 14, 2008 | 11:33 AM
aw1563t's Avatar
Thanks for the responses. Got to checking electrical connections out at the main buss under the hood. But what I did notice isthat when this shifting problem happened...these items stopped working, dome light, door locks & radio(sometimes not on). Checked the buss connections at the console, found loose connection from (red) power at back of buss. Changed connector, ok. Don''t know if it was time for loose connection or not, but that''s what it was.
Old Aug 14, 2008 | 12:42 PM
Low Saturn's Avatar
Hopefully that tunes out to be it. Kinda nice when its something simple.
sean1999
Jun 6, 2015 10:52 PM
Eaglescout
Nov 17, 2014 07:19 PM
Stampede
Jul 9, 2012 11:48 PM
cycle171
Nov 13, 2008 12:29 PM
Notahonda
Jul 16, 2008 12:30 PM
