95 saturn sl1 makes grinding noise
Old Jun 28, 2011 | 01:33 AM
BigE-78's Avatar
Default 95 saturn sl1 makes grinding noise
I have a '95 saturn sl1 5speed and it has 167,000 miles on it. lately i have been hearing this awful grinding type nosie that is coming from my passenger fron tire i have popped the hood and tried to find it but cant. the noise stays the same when idleing and when im dring any ideas
Old Jun 28, 2011 | 09:04 AM
oohrah's Avatar
Not sure of the name but there is a pulley that is mounted to the head. You may loosen your belt and see if is worn out. Think it may be the idler pulley, maybe
Old Jun 28, 2011 | 03:14 PM
BigE-78's Avatar
okay everytime that i rev my engine the noise gets louder and when im driving if i accelerate the nosie stops but once i slow down the noise is back
Old Jun 28, 2011 | 03:18 PM
I believe you are referring to the tensioner pully that keep the serpentine belt tight. The bearing can fail, and it'll make a gosh-awful noise. While you're at it, check the serpentine belt as well. If you see wear and/or dry rot, replace it too ....
Old Jun 29, 2011 | 01:13 AM
oohrah's Avatar
na, the tensioner pulley sets back and below. It is the idler pulley. It is stationary and non-adjustable.
Old Jun 29, 2011 | 06:51 AM
HHmmmmmmm.......
Lessee here -- water pump, crankshaft, A/C, alternator, pwr steering, tensioner. That's six round thingys, and I'm outa thingys
Old Jun 29, 2011 | 10:56 AM
oohrah's Avatar
Let's see,
I have an 95 Saturn SL1 vin code 8 (SOHC)
What I see and what AllData list for that model is 7 pullies
I have the following :
Crank pulley (at bottom), alternator, power steering, belt tensioner, idler pulley, A/C compressor and water pump
the top center pulley is the idler pulley.
Old Jun 29, 2011 | 03:06 PM
scotterichmond's Avatar
Here is a sugestion...............
Get a long,( really long) screwdriver, or wooden dowel, touch it to a part you think is too noisey and then to your ear lobe and the noise will be transfered to your ear. keep searching till you "find"/ "hear " the noisey part.
They accually sell a steth-a-scopes for mechanics you can buy too !
Old Jun 29, 2011 | 05:50 PM
oohrah's Avatar
I like your recommendation there Scott. Forgot the ol broomstick approach. Is very handy to run those thingy's down sometimes.
karljesse
May 25, 2013 07:54 PM
sl2owner
Jan 25, 2011 01:28 PM
tshp6576
Sep 27, 2009 09:12 AM
Capy
Apr 24, 2009 11:05 PM
latestgood
May 5, 2008 09:20 AM
