94 SW2, twin-cam
Old 04-27-2008, 06:05 PM
tra757's Avatar
I have a very odd problem that has been plaguing my SW2 for more than a year. It has left me stranded several times and this morning it left me at home.Everything will be hunky dory and then I hop in and twist the key and everything goes black, lights, gauges, radio, everything just goes dark.When I put a charger on it that can feed 60 amp and a volt meter across the battery, when the switch is turned to "start", the amp meter pegs and the voltage drops to 2 volts. I can hold it there for 5 seconds or more without any smoke, flames or smells of burning anything.I pulled it down the block and got it started but noticed that when I increase the rpm, the dash lights would blink erratically. I have cleaned the battery terminals and ground connections. I have checked every connection I can find that might be even remotely related. I was going to pull the starter and make sure it engaged and turns, but after that rpm-dash-lights-freaking-out incident, causes me pause.So here I am in pause. Can someone press the play button?Thanks,TR.a
Edited by: sw2cam
Old 04-28-2008, 09:41 AM
Low Saturn's Avatar
Recheck the positive battery connection. Corrosion can get inside the cable causing exactly what your are describing. It is very common. More so if the car has an A/C Delco battery.
Old 04-28-2008, 10:08 AM
tra757's Avatar
It's the battery. I touched the terminal lugs with an old UPS battery and it fired right up. I put the old one in and no workie.
Interesting.
< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-47";
urchinTracker();
Old 04-29-2008, 06:54 AM
TheEngineer's Avatar
I love when a simple fix seems to be the solution to a pita problem. Good to hear it
NMRAmustangracer
05-26-2014 02:19 PM
95_sl1
06-28-2008 12:58 PM
MINICooperS
04-22-2008 08:59 AM
the4ork
08-31-2007 07:18 PM
Bobcat698
03-09-2007 08:00 PM
Quick Reply: 94 SW2, twin-cam
