93 Saturn SL2 Warning Beep
Old Apr 23, 2009 | 10:20 AM
jkell65's Avatar
Question 93 Saturn SL2 Warning Beep
93 Saturn SL2 continues the warning beep, when I open the door, even though the keys are out of the ignition and the lights are off. Just started a couple of days ago, and consistently does it all the time. Curious if anyone has an idea where I can start looking...perhaps it's a fuse or something with the ignition. Thanks
Old Apr 23, 2009 | 09:28 PM
The sensor inside the key switch assembly that triggers when the key is still in the lock is broken
Old Apr 23, 2009 | 10:14 PM
sometimes it just gets jammed up in the position that it would be in if the key was there -- if you jiggle the key in the ignition you may be able to get it back the way it should be.
Or, like OA said, it's broke and will chime forever. I think there is some other important/useful stuff that shares the chime fuse, so check the owner's manual before you just go and pull it....
Old May 3, 2009 | 02:50 PM
GMunny's Avatar
I have the same issue, but its been going on for over a year.
rpgibbs
Oct 16, 2013 12:22 AM
krazy Dan
Jun 18, 2013 05:43 AM
bacobra777
Nov 15, 2010 04:24 PM
cali_saturn
Jan 4, 2008 06:57 PM
burzurq
Mar 26, 2007 06:11 PM
