92 SL problems
Old Jan 15, 2013 | 02:25 AM
saturnrockr559's Avatar
Default 92 SL problems
I just recently bought a saturn and it has a few issues i cant figure out
One the cooling fan isnt kicking on i checked the relays and fuses and there fine i was seeing if anyone had any ideas on it
two I live in cali and when i tried smogging it it didnt pass the smog guy said its cause its burning to much fuel i was wondering if anyone could be help
thanks
Old Jan 15, 2013 | 08:20 AM
ECTS is likely defective and will cause engine to run excessively rich when it fails. Never seems to throw a code.
Change ects (two wire coolant sensor mounted in head) and connector.
Use gm dealer parts.
Old Jan 15, 2013 | 09:02 AM
When you replace your ECTS, make sure you get one with the metal tip. Also, it's always a good idea to change out the electrical connector for the ECTS at the same time. Adds a little cost to the job, but makes for a much better connection.
As always, use OEM parts ...
Old Jan 15, 2013 | 09:24 AM
Old Jan 16, 2013 | 04:52 PM
ok ill check that all out im also having a problem with my seatbelts it has the seatbelts that slide when u open the car door and those havent been working do u know why those havent been working wither
Old Jan 17, 2013 | 07:57 AM
either fuse is blown, motors are dead, control module is dead, or any combination of the above.
Old Jan 17, 2013 | 08:27 AM
Don't forget it is cable operated and the cable wears and jumps the track and jams. How do you fix it?
When mine did that it was till under some kind of warranty. Should it happen again. As far as I am concerned you don't fix it.
If you do find a blown fuse and replacing it does not take care of things, then see previous sentence and learn to live with it.
Or figure out how to install aftermarket shoulder belts. The are available and it would probably be more affordable to buy and install them along with taking care of what ever interior or cabin cosmetic are damaged by the installation.
Old Jan 17, 2013 | 02:43 PM
oh, the car should have shipped with two metal hooks in the glove box that you insert into the tracks about shoulder height. They have the male end of the seatbelt latch and thus allow you to securely attach the seltbelts.
Forgot about the cables.
I traded in my 92SL2 back in 97 -- when the seatbelts still worked
betinaq
Jul 14, 2005 01:23 AM
