2001 Sl1 wierd idle problem..
Old Jan 10, 2007 | 07:58 PM
-euro-'s Avatar
Hello everyone.. my GF owns a 2001 Sl1 manual.. the car was starting to drive weird so i asked if she ever had any kind of tune up she said no.. so i replaced the plugs with new plugs from the dealer.. .. also replaced the wires.. after doing this the car started to idle high.. i thought well maybe its what i changed.. it wasnt.. put all the orignal stuff back on it and still revs high.. the wierd part is that if she puts on her AC it will idle normal..?? also isprayed carb claner to see if she had any leaks and the idlw whould changed when i sprayed around here injectors is that a common problem for injector seals to go? car has 60k on it..any info would be great..
-mikeEdited by: -euro-
Old Jan 14, 2007 | 12:38 AM
answerman's Avatar
Sounds like an Intake manifold leak. Injectors are in the same area so would seem to be the cause. Also check for vacume hose leaks in the area you sprayed carb cleaner.
rdrunnr
Sep 6, 2016 09:53 AM
saturnbabe
Apr 28, 2011 09:30 PM
jbcbussoft
Oct 23, 2009 05:20 PM
TonyHines
Jul 9, 2009 01:57 AM
turbozeke418
Apr 29, 2008 02:06 AM
