2001 Saturn SL1 Turns Over but Won't Start
Old Jun 23, 2009 | 11:58 AM
2001SaturnSL1's Avatar
Default 2001 Saturn SL1 Turns Over but Won't Start
Hello Everyone, I'm new to the forums and am having some issues with my 01 SL1, the starting issue only seems to happen when the car sits for say 1-2 hours after being driven. The car turns over but it won't start. The alternator and battery are fine, I can't seem to locate the issue here. The fuel pump was just replaced and it still does not work.
Now if the car sits for a few hours and cools down completely it will start up, it idles horribly and very rich but after a few seconds it's fine.
I hear there is a Crank Position Sensor problem with these cars, anyone think that could be the issue here? If so where is it located and how much of a pain is it to replace?
I appreciate and info
Thanks
Josh
Old Jun 23, 2009 | 02:58 PM
Hi there Josh --
You got the right idea, but the wrong sensor. The one you need to replace is the Engine Coolan Temperature Sensor (ECTS). It is located on the driver's side of the engine, below the place where the water exits the engine to the radiator. The sensor costs about $14usd (GET THE OEM TYPE).
It's also a good idea to replace the connector for the sensor at the same time. The connector costs a bit more (about $25usd), but the contacts tend to get bad over the years and makes for a poor connection.
Final comments -- use Teflon tape on the threads of the new sensor, and do the work when the engine is cold to avoid scalds/burns
Old Jun 24, 2009 | 01:12 AM
Thanks for the help!
I replaced the Crank Pos Sensor and Coolant Temp Sensor and the car starts fine. What a relief that is.
Now I am having an issue with a misfire at cylinder 1, I am thinking it's an issue with the coil packs but I am not 100% sure. Any ideas? Also which cylinder is cylinder 1?
Also does anyone know the firing order? I'm not sure that the wires are ran correctly and before going through the trouble and $$ to replace the packs I would like to make sure the right cylinder is firing when it should.
Thanks again
Josh
Old Jul 22, 2011 | 02:09 PM
saturnchix's Avatar
Default SAME SYMPTOMS you had cps or ect?
glad to see your car worked when changing both sensors....but since you changed them at the same time, how do you know which sensor worked for your problem CPS OR ECT????
i am experience same symptoms, and the obdii threw a tps SENSOR which i asumed was the throttle position sensor, so i changed that and still have the same problem.
i think i changed the ect 30k ago, 6 years ago, so dont know if that went bad again, 98 sl2, with only 70k!, let me know if you can help thanks!!!
Old Jul 23, 2011 | 06:00 AM
SNIP
SNIP
On an in line 4 cylinder engine, or as far as I have been able to tell any engine of any configuration the cylinder the furthest away from the back of the engine (that is where the transmission is bolted up to) is #1. #2 on an in line engine is generally the next cylinder, a V configuration #2 can get a bit tricky. As to firing order:
it's on a sticker under the hood. the cylinders numbered 1-2-3-4 and the ingnition wires are 4-1-2-3 on the coil packs. the firing order is 1-3-4-2
Old Jul 24, 2011 | 10:07 AM
saturnchix's Avatar
Default ect or cps??
regarding SATURN01 problem, does anybody know if it was the ect or cps that helped his problem???
i was havin same symptoms?, please let me know
also where and how hard is it to change the cps???
thanks!
Old Jul 24, 2011 | 10:58 AM
change two things at once = never know but likely the ects for starting issues
Old Dec 1, 2024 | 12:30 AM
Subsailor696's Avatar
Thanks again
Josh
Hi Josh. I had the cranking no start issue with my 2001 SL1 also, and racked my brains trying to find the problem. I finally traced it to excessive corrosion on the fuel pump relay pins. I sanded the pins down to shiny copper, reinstalled the relay, and it started right up. Hope this helps. -Subsailor696
Old Dec 1, 2024 | 07:57 AM
Hey Subsailor696, Joshs' post was dated June 23rd, 2009. He NEVER came back. We do appreciate your input, however, because it might just help someone else that may have that problem. Nobody knows whatever happened with Josh.
Rizzu7
Feb 19, 2013 12:28 PM
TJGator
Jan 19, 2013 07:34 AM
olso2276
Jul 24, 2010 10:06 PM
Lissa
Jul 2, 2010 11:44 PM
WiShJ1
Apr 5, 2007 03:02 PM
