2000 SL2 Oxygen Senor Replacement
Old Jun 17, 2011 | 02:04 PM
Stick's Avatar
Default 2000 SL2 Oxygen Senor Replacement
Can anyone tell me where the O2 Sensor is Located on the 2000 SL2 DOHC? I need to replace it. Are there any special tools that I need?
Thanks in advance.
Stick
Old Jun 17, 2011 | 02:11 PM
scotterichmond's Avatar
There are 2. One is in the exhaust manifold the other is down stream in the exhaust pipe, I believe after the cat. Boxend wrench should do fine, but they do make a special socket for them. Why do you need to repace it?
Old Jun 17, 2011 | 02:18 PM
Stick's Avatar
Trying to eliminate codes. I wonder which one is making the code?
Old Jun 17, 2011 | 02:28 PM
http://www.engine-light-help.com/gm-trouble-codes.html
What codes are being set ?
This might help do you have a scnner that can watch the O2 sensor voltage?
Old Jun 17, 2011 | 02:40 PM
Stick's Avatar
Thank you for the link and tip. I most likely will replace both of them if they are readily accessible. No scanner available.
Old Jun 17, 2011 | 02:50 PM
Repacing them won't hudt anything, but why would you replace the sensors?
What pointed you in that direction?
Old Jun 17, 2011 | 02:54 PM
Stick's Avatar
Wow! Napa says $94 for the rear sensor and $67 for the front one. The auto shop who did the scan told me the 02 sensor code.
Old Jun 17, 2011 | 02:57 PM
that's about the right price, most times it is the front one. It is a crap shoot with out the scanner.
Old Jun 17, 2011 | 04:45 PM
post the code or play roulette with your hard earned dollars...your choice
challenger99
Aug 9, 2009 07:42 AM
FasterNU72
Saturn L300
Feb 26, 2009 10:41 PM
josaL200
Dec 4, 2008 08:16 PM
fosgate3
Jun 10, 2008 10:02 AM
Franki
Mar 11, 2008 11:40 AM
