1999 SW2 stalling problem
Old Aug 15, 2010 | 03:09 PM
sirpjmud's Avatar
Question 1999 SW2 stalling problem
1999 Saturn SW2 stalls out after warming up and will not restart until cold again. Also very high RPM when running. Changed fuel filter but still same problem.Could this be the crank position sensor? If so where on engine is sensor located? I have looked and can not find it. Feeling stupid.
Old Aug 15, 2010 | 05:45 PM
The crank position sensor won't normally be temperature sensitive, but the engine coolant temp sensor definitely would be. Try changing that first
Old Aug 15, 2010 | 09:36 PM
hoseppi's Avatar
10-4, a defective CTS would definitely cause hot start problems. Make sure the connector is clean.
Old Aug 16, 2010 | 08:28 PM
sirpjmud's Avatar
replaced CPS today and it seems to have solved the problem.
mascencerro
Jan 23, 2013 04:06 AM
tfg11199
Oct 17, 2009 09:44 PM
JAFO1
Engine & Internal
Jul 9, 2008 08:19 PM
jennmcayer
Aug 23, 2007 11:09 AM
jillowolf
Jan 14, 2006 08:51 AM
