1999 SW2 auto trans shift problems
Old Aug 12, 2024 | 06:26 PM
Gigi7)'s Avatar
Default 1999 SW2 auto trans shift problems
Just joined so I don't know if I'm in the right area for this.
SW2, 240K, runs amazingly smooth, no check engine light, rev's up great in neutral, changed radiator now suddenly not accelerating properly or shifting correctly. Probably just a coincidence but I don't know. First checked to see if the radiator trans fluid cooling tubes were clogged, not clogged. changed the two (2) external sensors ( i think they are output and crank) no change. changed the fluid and filter, Nope. Found some info online but not much. One recommendation was to change the forward shift sensor inside the transmission, changed. still not fixed. If I take off slow and accelerate lightly it shifts ok but this is not acceptable for entering a hwy. Moderate gas, it will go but will not shift in third unless I lightly let off the gas. Too much gas and it falls flat on its face, Poor rpm and not shifting correctly at all. When I do get it up to third it will go to 4000 rpm and as soon as i just let off the gas a little it will shift. Once up to 55mph it goes fine but still no pep if I have to give it the gas. Any Ideas? Thanks, Mac
Old Aug 12, 2024 | 07:51 PM
grcauto8453's Avatar
You are changing sensors and not sure what they are>
Old Aug 12, 2024 | 08:21 PM
Gigi7)'s Avatar
Default Yup, no clue what I'm doing
Yes, The car is just a beat around car and has no real value so I figured I'd have some fun and give it a shot. I only changed the one that is toward the front of the car. Any Ideas on what I might try next? As unscientific as it is, I did remove each one and put on a rubber hose and blew through them unenergized and each allowed air through. Then I energized each and they clicked and with only as much pressure that my lungs could muster they all appeared to close. Any help would be appreciated. Thanks
Old Aug 13, 2024 | 07:48 AM
Check and see if you catalytic converter is stopped up. And quit changing parts when you have no reason too. You're just creating more problems for yourself.
Old Aug 13, 2024 | 12:04 PM
Gigi7)'s Avatar
I thought the same thing even though the entire exhaust was replaced 6 months ago. checked it anyway, totally clean. Any more Ideas?
Old Aug 13, 2024 | 12:29 PM
Gigi7)'s Avatar
I tried that. Although the complete exhaust system was replaced 6 months ago, I checked for a clogged cat, Nope it's clean.
Old Aug 13, 2024 | 03:01 PM
By complete you mean resonator?
Just making sure
Old Aug 13, 2024 | 03:02 PM
Service engine soon light on?
Codes? Just the code not the description
Old Aug 13, 2024 | 05:20 PM
Gigi7)'s Avatar
no light on and I Checked, No codes
Old Aug 13, 2024 | 06:29 PM
Scanner or reader?
Does your device read TCM codes? BCM codes?
