1998 Saturn SL to transmission sticks in first gear
Old Sep 13, 2020 | 12:38 PM
Tubby's Avatar
Default 1998 Saturn SL to transmission sticks in first gear
98 Saturn SL two transmission sticks in first gear from time to time when taking off. If I throw it in neutral shut ignition off restart it throw it back in gear as I’m moving it shifts OK again. Check engine light comes on when this happens. After a couple restarts it will be off again.
Old Sep 13, 2020 | 02:27 PM
Please stop by AutoZone or similar and have them read the codes for the check engine light. The light needs to be on for them to capture the codes.
Please post the codes as Pxxxx where the X's are numbers. Please do not post the supposed description of the code that the AutoZone guy gives you. Ask for a printout of the codes.
And for the love of Saturns, do not buy anything they try to sell you.
Old Sep 14, 2020 | 06:57 AM
I agree with derf. And especially when he says DON'T buy anything from the Zone. I worked for them for 5 years and to this day the ONLY thing I'd buy from them is a Duralast Gold series battery. Nothing else.
Old Sep 14, 2020 | 10:54 AM
Likely a solenoid issue/valve body issue/???
Could also be an issue with the Transmission Control Module (TCM) getting flaky.
Just guessing.
The codes should tell you.
pokerpete
Saturn Astra
Oct 15, 2018 06:01 PM
mandee_07
Aug 29, 2015 02:16 AM
lukesteeler89
Jul 22, 2013 01:57 PM
turbochargedv8
Oct 12, 2009 07:10 PM
whitewtrkayaker
Nov 23, 2008 06:29 PM
