1996 sw2 questions....
Old Jan 16, 2010 | 06:35 PM
canbquik's Avatar
Default 1996 sw2 questions....
Hey guys, have a 1996 sw2 with 108,000 on it. Runs great, but have a couple questions.......
1 the temp warning light comes on randomly, then goes out???????
2 what spark plugs are best, got bosch 4301's.
3 is the sub frame rusting out common on these cars, got it inspected and they told me that the driver's side sub frame was rusting out, will post pics tomorrow, but I don't see it. Maybe someone else can shed some light.
thanks for all help, Chris
Old Jan 17, 2010 | 07:48 AM
Get plugs from the dealer, bring the bosch plugs back
Are you sure it's the water temp light not water level light
Not common for the frames to rust
Old Jan 17, 2010 | 08:28 AM
canbquik's Avatar
no dealer in the area..... which should I go with?????
Old Jan 17, 2010 | 07:09 PM
Plugs -- NGKs per owner's manual
If it is the coolant low light, you need to pull out the coolant reservoir and clean it -- the switch is at the bottom. If you're low on coolant to start with, you have bigger cooling system issues.
If that does not work -- replace the coolant level sensing switch
mlciro
Jun 25, 2015 08:46 PM
mstellar
Jun 12, 2015 02:21 PM
vicart
Jan 14, 2012 10:53 PM
SW2-96
Jun 13, 2011 01:15 PM
Zandar
Jan 22, 2010 06:35 PM
