1996 Saturn SL Over heating while idling
Old Jun 24, 2013 | 10:49 AM
Vanderworkenm's Avatar
I wouldnt say its a muddy milk shake but its not healthy looking either
Old Jun 24, 2013 | 08:24 PM
If you have one hanging above your workbench (compression gage), take it down, and run a test on your engine ....
Old Jun 24, 2013 | 10:15 PM
What do you mean by it's not healthy looking? Do you have water bubbles on the oil dipstick? Maybe the coolant has never been changed. I'd recommend a flush of the cooling system and a fresh refill with a 50/50 blend of antifreeze and distilled water.
Old Jun 24, 2013 | 10:49 PM
After checking the water pump for signs of leaking. After checking top drivers side of radiator on the engine side for swelling or cracking. Flush and refill .............. replace pressure cap.
If at one time someone replaced the ETCS with one from AdvanceO'ReillyZone you could very well be getting an incorrect temp reading at the guage, that also means your getting an incorrect signal being sent to the PCM.
Old Jun 25, 2013 | 02:42 PM
I plan on flushing it first thing in the morning, and by not healthy looking I mean it is brownish, and no I don't have a compression gage... today I turned the ac on so the fan would stay on and the temp. stayed right around the 3/8 mark like usual... Thanks for all the help you all have provided.
Old Jun 25, 2013 | 04:54 PM
Yep, if it's brownish in color it's way past time to flush and refill the system. I think you'll see an improvement in the way it performs once you do this.
Old Jun 25, 2013 | 10:15 PM
okay that's good, yeah first thing in the morning im going to go ahead and do it... ill get back to you all with details of performance and what not after it gets flushed in the morning
Old Jun 26, 2013 | 01:59 PM
keith's Avatar
I hope you don't use any chemical flushes. If you flush, just use plane water, however, I would just drain and refill with fresh coolant at a 2:1 concentration with distilled or purified water, or use premix.
rjs
Dec 13, 2013 10:30 PM
5.9cummins
Jul 14, 2013 12:56 PM
Chainsaw
Sep 19, 2011 05:54 PM
rosiegirl1
Aug 8, 2010 04:38 PM
SL2 pirate
May 9, 2008 09:33 AM
