1995 Saturn SL2
Old Nov 17, 2009 | 11:03 AM
Barkinspyd3rs's Avatar
Default 1995 Saturn SL2
What weight Oil should I use in this 1.9 L and how many quarts should it Hold? Would you recommend using Synthetic Oils?
Old Nov 17, 2009 | 02:34 PM
saturnsdn's Avatar
5-30 is recommended but 10-30 is usable depending on the temps you see. holds 4 quarts and as far as synthetics if you burn which you possibly do as most do I wouldn't unless you really want to
Old Nov 18, 2009 | 05:37 AM
No Burn, the motor has been rebuilt and only has 4,000 miles on it!
Old Nov 18, 2009 | 07:39 AM
go synthetic -- mobil 1 5w30. Change every 3K and you will likely not develop an oil burning problem.
Old Nov 19, 2009 | 11:46 PM
saturnsdn's Avatar
agree with derf then but since nothing had been said about the engine being recently rebuilt I took it that it hadn't been
Old Nov 20, 2009 | 06:06 AM
fair enough -- no need to defend your comment -- we're not clairvoyant...
tx77015_ls1
Feb 10, 2010 06:32 AM
tx77015_ls1
Jun 3, 2009 03:43 PM
smkarpik
May 15, 2009 02:14 PM
ernest
Oct 14, 2008 09:58 PM
projectpete19
Dec 12, 2006 09:06 PM
