02 SL2 PCM Problem
Old Feb 16, 2011 | 08:20 AM
twoSL2s's Avatar
Default 02 SL2 PCM Problem
I was starting to have random problems(temp guage went to hot immediately, gas guage quit working, after about a week temp guage stopped working at all, engine/transmission temp light came on). Then the car wouldn't idle when cold. I pulled the PCM and found corrosion from the battery on the side of the PCM. I bought a PCM from a junk yard and installed it, but the car would not start. I was reading another thread about flashing the PCM. Is this what I need to do?
In desperation, I cleaned the corrosion off of the old PCM and re-installed. All of the problems were gone. Now about a month later, I am starting to have idling problems again.
Any other ideas???
Old Feb 16, 2011 | 01:23 PM
?? Maybe clean the connections again ?? Other possibility is a worn/bad connection in the PCM hookup itself .....
Old Feb 16, 2011 | 09:17 PM
White vinegar and a small brush or cotton swabs will go a long way toward cleaning battery corrosion off of the terminals. When clean coat with (I think it is called) conductive grease. Sold at auto parts stores in a tube used to electrical connectors in cars including light bulb sockets and all, will help prevent further corrosion. I first saw this stuff to be used on points when changing them in distributors. Since then wider usage in all automotive electrical connections.
I keep a tube of this around all the time to re-coat pins and such when I unplug a connector or change a light bulb.
Old Feb 16, 2011 | 10:08 PM
that would be known to us youngins as dielectric grease
Old Feb 20, 2020 | 07:49 PM
cobbleup's Avatar
It's called "dielectric grease" ....it's non conductive
Old Feb 20, 2020 | 07:51 PM
cobbleup's Avatar
It's called "Non conductive or Dielectric" grease
Old Feb 21, 2020 | 12:34 AM
Thank you for re confirming that for this 9 year old post.
Twice.
Closed.
nsibert
May 16, 2013 05:41 PM
Sleepy SL
Suspension
Sep 1, 2011 07:57 PM
MISaturn
Dec 24, 2010 12:46 AM
uncljohn
Headers, Intake, & Exhaust
Aug 3, 2010 07:12 PM
Ebuddy
Saturn L300
Jul 30, 2010 06:30 PM
