02 SL1 Missfire SOHC
Old Aug 2, 2010 | 05:48 PM
jacobshain's Avatar
Default 02 SL1 Missfire SOHC
I've swapped coil packs, wires, plugs (gaped .040), and it's still a number 1 misfire. It also calls for a new EGR Valve but the auto part store only has the solenoid sitting under the intake. Any takes on the issue?
Old Aug 2, 2010 | 10:15 PM
check compression
and what calls for new egr valve?
Old Aug 2, 2010 | 10:18 PM
hoseppi's Avatar
Might be the intake manifold gasket. Squirt some ether or carb cleaner in the vicinity, and see if the idle evens out.
Old Aug 2, 2010 | 10:19 PM
oh dammit hos, your ideas are always better than mine
Old Aug 3, 2010 | 07:40 PM
hoseppi's Avatar
Derf, I don't know about all that.
Old Aug 12, 2010 | 10:53 PM
helistructor's Avatar
Pull the EGR valve and see if it is sticky. I had one where it caused all kinds of problems. Cleaned out the egr valve the best I could with a screw driver and carb cleaner, stuck it back in, with a new gasket from the parts store, ( about 3 bucks), and the car ran like a dream! Don't buy a new EGR until you absolutely have to!
Old Aug 13, 2010 | 02:47 AM
Good 4 U! I have not had an EGR problem in my Saturn yet. But then again, have not driven the miles on it. Did have a Mistusbishi I put a ton of miles on that had a sensor that monitored EGR operation. About every 70 or so thousand miles I would get a check engine light and the Code was an EGR valve. Found I could clean it with Carburator cleaner as it was caboned up and re-install it. For some reason or another was looking in a wrecking yard for Mitsubishi engine parts and I never saw another with the sensor. Don't know why, but when it carboned up where the light came on, the engine also ran like garbage so maybe it was a good thing. Gonna have to remember this if my Saturn ever runs that lousy.
calvintanner
Sep 26, 2010 05:23 PM
LinkFarms92
Mar 17, 2010 11:42 AM
Bing
Feb 3, 2009 07:49 PM
sl1fan
Jul 10, 2008 01:43 PM
pacbrown
Jan 14, 2007 03:41 PM
