01 sl1 miss at idle
Old Feb 22, 2008 | 12:48 PM
mattiemo's Avatar
my gf's sl1 has a miss when it idleing. there is no check engine light on but it also has had erratic idle for the past few months (sometimes high idle 1500-2000 some times it misses and almost stalls) any idea what could be causing it
Thanks
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old Feb 22, 2008 | 06:48 PM
original007's Avatar
intake gasket most likely leaking spray carb cleaner near the intake/power steering pump area see if the idle changes.
Old Feb 23, 2008 | 09:19 AM
keith's Avatar
If you let it idle for two minutes after it has warmed up, you should get a
check engine light for the high idle. It should be P0507, you can get it read
for free at any AutoZone or many other parts stores.
Ignore all the recommended fixes until after you do what original007
suggests which is to spray wd40 or carburetor cleaner around the intake
manifold gasket around the #1 cylinder. Any change in the idle will confirm
that you need a new intake manifold gasket, a common problem with these
engines.
Jobolt
Jul 14, 2015 01:26 AM
grampatampa
Jun 22, 2009 09:12 PM
caldi
Sep 18, 2008 04:06 PM
pork chop
Aug 28, 2008 12:13 PM
4kart5
Jul 20, 2007 09:08 PM
