not running good
Old Mar 17, 2007 | 07:25 PM
billyjoe's Avatar
92 saturn was running good. abuot 20 miles in to my drive started to run rought then quit runing.when it starts up in wont run less you theter the gas.idels up and down.wont run smouth.any ideas.
Old Mar 17, 2007 | 07:29 PM
billyjoe's Avatar
any boby need 92 saturn parts good 5speedtran.body partsgood4good doorspowerwindows.
Old Mar 17, 2007 | 08:09 PM
Clean EGR valve and the ports it connects to.
Old Mar 18, 2007 | 12:33 AM
ducky's Avatar
Have you checked the engine coolant temperature sensor (ECTS), that's prone to cracking? The symptoms of a failed coolant sensor would either be running rich and idling high or fails to run and stalls unless blipping the gas pedal. The original coolant sensor is made of resin and very problematic unless replaced witha newbrass sensor.
Old Mar 18, 2007 | 01:41 PM
billyjoe's Avatar
thank for info on 92 saturn.billyjoe.
Old Apr 18, 2007 | 01:06 AM
Why did you post about a SL in the L300 forum?
quadcoupe
Feb 25, 2015 06:27 PM
woodsheder
Jun 12, 2012 10:33 PM
Irish Pride
Aug 24, 2011 11:12 PM
kbankovi
Feb 26, 2007 02:07 PM
dgi007
Audio/Visual Electronics
Apr 2, 2006 05:08 AM
