2004 Rear brakes
Old Jan 14, 2020 | 07:16 PM
cincydh's Avatar
Default 2004 Rear brakes
My son just bought a 2004 L300 6 cylinder. i know the rear brakes need replaced and found out that they are pinned and seem pretty simple to install. My question is what to grease like caliper slides etc. There's very little info on youtube. Thanks for the help in advance.
Old Jan 14, 2020 | 11:07 PM
There are no moving caliper parts except the pistons that push on the pads themselves. Remove the two pins, open the bleeder, slowly push the pistons back into the caliper. Close the bleeder, install the new pads, install the two pins. Press on the brake pedal a couple times. Open the bleeder and see if only fluid comes out. If so close the bleeder and you are done with that side. Repeat. Top the brake fluid in the master cylinder. Torque the wheels.
Old Jan 15, 2020 | 07:47 AM
cincydh's Avatar
Wow definitely a new for me ! I'll be tackling them tonight Then I'll be installing a coil pack for the P0304 cylinder misfire code. Thanks !
cpeiffer
Aug 24, 2017 10:00 AM
asbennett
Feb 25, 2017 10:09 AM
blakesdad
Nov 14, 2009 01:01 PM
lfowkes
Sep 24, 2009 06:35 PM
ericwgrabosky
Jul 16, 2009 12:49 AM
