Why is this happening
Old May 28, 2024 | 04:38 PM
Magician_val's Avatar
Default Why is this happening
Gray smoke or vapor coming out of valve cover. . If I Pull out Dip stick, smoke come out of there too. if I wiggle pcv valve smoke comes out of there too.. after unclipping air filter cover and lifting it up I see Oil getting into my breather box. I hear a small vacuum leak But can't find where the leak is. My oil isn't mixing with my antifreeze and there is no oil in my reservoir tank. Recently replaced spark plugs and wires . please someone. If you got any advice. I could use some...
**Update** . I have not been drinking or smoking. Was outside working on car at the time. I guess it was hard to follow what I was asking. Hope this edited version helps.
Old May 28, 2024 | 04:48 PM
My advice is to please provide a description of your issue or issues that is comprehensible. I for one do not know what you are asking because your post is all over the place. We all aim to help,
Old May 28, 2024 | 05:10 PM
grcauto8453's Avatar
I recommend cutting down on the alcohol. A lot.
That1dude
May 11, 2024 11:20 PM
Dave4422
Jan 11, 2016 07:39 AM
mallengrace
Feb 23, 2014 07:34 AM
Howard_Woodard
Sep 23, 2013 11:24 PM
96_SC2
May 25, 2007 04:36 PM
