Tlj
Old Aug 14, 2020 | 11:16 PM
TLJ's Avatar
TLJ
Default Tlj
2000 ls2 just dies ocasionally.took and got code read said it was internal control module. Does this sound right ? Where is it? Cant seem to find much on this when looking ignition control module comes up. Same thing??? Daughters car she says she shuts off everything waits a minute and it starts right back up.
Old Aug 15, 2020 | 01:12 AM
Please post the code itself. It will be in the format
Pxxxx where each x is a number from 0 to 9. .This will allow us to determine which module is likely causing the issue..
Be sure to include all codes along with any other "problems" w the vehicle (eg rough idle, overheats, shifts roughly....so we get an overall picture of the situation. Seemingly unrelated problems can share a common cause
Old Aug 15, 2020 | 10:32 AM
I have a 2002 factory service manual set for this car. If you can get the actual codes I can help.
Old Aug 15, 2020 | 01:44 PM
TLJ's Avatar
TLJ
error code read: P0601
Old Aug 15, 2020 | 08:17 PM
Old Aug 15, 2020 | 08:19 PM
I would try another ecm and do the passlock relearn. I can post that procedure if you choose to go that way.
Old Aug 15, 2020 | 08:20 PM
Where are you? I have spare parts.
Old Aug 17, 2020 | 06:52 PM
TLJ's Avatar
TLJ
Montgomery,Illinois
Old Aug 17, 2020 | 07:48 PM
If you purchase an ecm at a local wrecking yard make sure you know the reason the car is there. I have purchased bad ecms from cars with no body damage. I think the 2000-2002 take the same ecm but have a wrecking yard verify. The 2003-2005 cars have some different throttle parts.
Jjames77
Aug 17, 2020 11:20 PM
choover82
Jul 3, 2013 10:52 PM
barnkat
Jul 25, 2011 08:37 PM
LS2power
Jul 10, 2008 08:40 PM
chitownrepoman
May 5, 2008 09:01 AM
