Loss of power and sputtering problems.
Old Dec 10, 2019 | 06:54 PM
xenowildfire@hotmail.com's Avatar
Default Loss of power and sputtering problems.
I am hoping that someone can help, i have a 2003 saturn LW300 and when I start the car it starts up fine, idles fine but when I start driving it starts sputtering and when changing gears it continues to do it and when the RPMs bounce up as the car is jerking like I hit and let off the gas plus the RPMs get up to 3000 or over that before it changes gears. I went to autozone when the check engine light was on and they checked it and it came up as a mass airflow sensor, said the fuel was too lean so i ordered the part and put it on today, well after I put the part on I hooked the battery back up and got in the car and it ran fine but later on I had to go somewhere and it ran fine for maybe 5 minutes and then started doing it again. The check engine light isn't on but there is a car with a wrench light that is on. I'm just trying to figure out where to go from here, any help would be appreciated, thanks
Old Dec 10, 2019 | 07:00 PM
DropDead's Avatar
Mass air flows are finicky.
If it is not stock, as in oem, chances are its gonna keep giving issues.
clean your throttle body and make sure your air filter is good as well.
Sounds like a maintenance light. I'm an ion guy tho. So I don't have that
Old Dec 10, 2019 | 11:28 PM
thank you, I will give that a try
Old Dec 11, 2019 | 12:33 AM
DropDead's Avatar
Be careful with thr throttle plate as well
Old Dec 11, 2019 | 06:18 PM
I cleaned it and put it back together. It ran good for 5 minutes and then started doing the same thing.
I'm going to exchange the mass airflow sensor out and see if the sensor I got was just bad.
Old Dec 12, 2019 | 02:10 AM
DropDead's Avatar
See if it has any pending codes
Old Dec 19, 2019 | 04:26 PM
I have replaced the mass airflow sensor and cleaned the throttle body but now the seems like it is worse and the harder I push on the gas it died out on me and wouldn't changed gears so I don't know if there is a hose that needs to be replaced or if something else is wrong
Old Dec 20, 2019 | 12:38 AM
DropDead's Avatar
Is it the 4 cylinder or 6 cylinder? I think the l300 is the 6 but dont remember.
Try unplugging the maf and starting. If it runs fine amd throws a code, of check wiring next.
Also check the vacuum lines coming from the intake manifold and throttle body.
Other thing I can think of is the engine grounds or a starter fuse maybe.
If you're close to east Texas I wouldnt mind taking a look at it to try and help.
Old Dec 20, 2019 | 01:02 AM
Ok I will try that next, thank you but I live in Florida.
Old Dec 20, 2019 | 04:00 AM
DropDead's Avatar
No problem. Sometimes I need a second set of eyes.
maybe the coil pack. Trying to brain storm for you
Ghostlight1
Nov 25, 2019 12:13 AM
BladeSmokeGT
Oct 11, 2017 08:58 PM
knorr713
Apr 3, 2010 10:02 AM
tsparks
Jan 20, 2009 10:24 PM
skdr112888
Aug 16, 2008 10:12 PM
