Pardon my ignorance, but what exactly would I lube.
Possibly the outside of the cyl, but people argue over whether it matters, collects dirt, finds its way to the electrical contacts of the ignition switch itself.
I use just graphite powder for the innards of the locks. |
(Post 48833)
hey folks --is there any recommended grease/lube for install (yes I remember he Ions)?
I believe this guy is replacing his ignition switch in an L series. Hope this helps!
I've replaced the ignition cylinder in my S-series and the trickiest part was getting the code and making sure it's correct in the new cylinder. The tumblers will have numbers written on them. Write these down on a piece of paper and match them up with the new tumblers you'll get with your new ignition cylinder kit. After a few months, I haven't had any binding or starting troubles with the ignition. Good luck! |
Awesome Videos! Thank you Dave4422!
I need to replace my trunk lock; I've had the cyl for three years but was afraid to mess w it as I have never done so and didn't want to end up w a disassembled broken cyl, an improperly config'd new cyl, and nothing to fill the hole in the trunk with (where the cyl goes). Maybe I'll give it a whirl
The new cylinder is installed and everything works great! Car starts every time. Thank you everyone for your comments. I appreciate it a lot.
Besides a 2001 L200, I also have a 1999 sw1 that keeps me busy as well. |
Spartan,
could you please make a signature like ours: First Name/Location (State) Year Model Engine Mileage for all Saturns Any other rides you wish to list top right of page clk your username>>UserCP>>Edit signature on left Thanks. |
