fuel gauge problem
Old Jan 16, 2012 | 08:59 PM
whitelee28's Avatar
OK so i took the car in and had the fuel level sender and pump replaced. The car still goes to full tank of gas and the security light stays on solid and the bell goes off. Also when the key is in the ON position the car doesn't ding it only does it when the car is running. I'm at a loss.
Old Mar 2, 2012 | 10:13 AM
whitelee28's Avatar
Hello all sorry for the late response. I have taken the car to a friend of a friends shop and I explaned the symptoms. The tech tested the gague cluster and it all tested good. The tech said that he is 99.9 percent sure its the BCM. So once the tech can determin if he can program the BCM i will get that changed. Ill keep you guys posted.
Old Oct 2, 2012 | 05:32 PM
whitelee28's Avatar
Hello all I finally broke down and took the car to a Chevy dealer. It is a body control module issue. It's about 749 to replace it and program it and all that. Thanks again for all of your help.
Old Oct 3, 2012 | 10:20 AM
Thanks for the follow-up on your problem. Too bad you can't locate a used BCM at a local u-pull-it facility
Old Oct 3, 2012 | 11:06 PM
whitelee28's Avatar
Yeah I had thought about going to a junk yard or eBay. Correct me if I am wrong but some sort of bypass has to be done for the security system to make the bcm work without programming it? I decided to go the dealer route because this is my fiances daily driver. If it was my daily driver I would have done that. I want to make sure she has a very dependable car so I forked out the money. To me it's worth it.
Old Oct 4, 2012 | 02:04 AM
ummm
can we stick to updating just one of the two threads that seem to have converged to the same topic
thanks
Peace
Derf
seatacwa
Sep 6, 2022 08:20 PM
uncljohn
Dec 10, 2012 11:02 PM
sevenhealth
May 31, 2011 07:18 PM
BradT
Apr 23, 2008 07:37 PM
cme030603
Sep 5, 2007 12:13 AM
