Cooling question
Old May 28, 2007 | 09:48 AM
tomdad's Avatar
Hi-new Saturn owner, can you tell me if this is normal. Now that it is hot out the temp gauge will read high especially when not moving. The gauge will go to about half way, which i checked is around 210. The cooling fan doesn't come on, but will come on when AC is on (which brings temp down) The ECTS seems to check out ok-but is difficultto check with the small pins. I haven't pushed it to see if the cooling fan comes on at a higher temp or it overheats. My question is this normal operation (the gauge moving to half way) or do I need to keep checking things
thanks Tom
Old May 28, 2007 | 02:03 PM
ducky's Avatar
Yeah, your temps are normal as the needle will go almost to the red line before the fan kicks in and the the temps will go down to between the 1/4 and 1/2 mark.As long as the coolant sensor isn't the original resin tipped one but a brass one you should be ok. Check this out; http://www.saturnfans.com/forums/showthread.php?t=24003and http://www.saturnfans.com/forums/showthread.php?t=37884
If you have the original coolant sensor replace it immediately before you have other problems.
hollywood32401
Dec 14, 2008 08:50 PM
Taipans
Oct 23, 2008 09:16 AM
saturnl300
Saturn L300
Sep 6, 2008 12:31 AM
Utah Joe
Jun 8, 2007 08:32 AM
hummvue
Feb 1, 2007 03:11 PM
