Converting 15" steel wheels to 16" alloys
Old Feb 28, 2017 | 09:40 PM
WalterB's Avatar
Default Converting 15" steel wheels to 16" alloys
My 2003 L200 has 15" steel wheels with hubcaps. It seems that all of the original stock alloys that are available are all 16". What am I missing? Can I just replace 15" wheels with 16" wheels? I'm trying to keep my car as original as possible.
Old Feb 28, 2017 | 10:41 PM
The 2000-2002 alloys are 15". I would love a set of Saab spoke wheels, I just don't want to buy a whole car to get a set. This ugly set of alloys came on my 02 l200/5 speed car.Name:  image_26.jpeg
Old Feb 28, 2017 | 10:46 PM
This set came on my 02 lw300, I saved them for my l200/5. Name:  image.jpg1_3.jpg
Old Mar 5, 2017 | 11:36 AM
One man's beauty is another man's beast.
Wouldn't his speedometer be off ? How do manufacturers tweak that on a vehicle? Does the VSS signal go to the PCM before the electronics of the instrument cluster so that multiple speed calibration curves are possible?
Old Mar 5, 2017 | 12:10 PM
Just stay with the same circumference tire for the speedo. The Lw had 205/65-15 tires, the l200 sticker says 195/65-15. The bcm drives the speedo, I plan to wear out the 205s then buy 195s. The only reason I described the first set of wheels as ugly was the corrosion not the style. If they were in nice shape I would have kept them. if I had a tech II I could probably adjust for tire size. I know I can adjust the Ford speedo's at work with the Ford program.
Old Mar 8, 2017 | 02:49 AM
Thank you, sir.
Old Mar 9, 2017 | 09:37 AM
19bonestock88's Avatar
It's also worth mention that as long as they calculate e new tire size to be close to the same rolling diameter, there won't be much speedo difference
SF Help & Suggestion Center
Mar 25, 2012 10:55 PM
92SL2
Feb 25, 2011 01:42 PM
timmerz
Feb 9, 2011 08:56 PM
RattRod17
Jan 28, 2010 10:40 AM
irishgrrrl
Jun 14, 2009 08:27 AM
