’98 s-series wagon
Old Dec 6, 2006 | 12:48 PM
soonersaint's Avatar
My 1998 standard trans. s-series is idleing high in gear and out of gear (up to 2100 RPM's) It also hesitates when trying to accelerate. this happens mostly at beginning of gear change when RPM's are low.It feels like it's missing. I have not taken it any where and it is my families primary car. I am tight this month so any advice would help.
Saturn...best car I have ever owned![img]smileys/smiley4.gif[/img]
Old Dec 7, 2006 | 01:09 AM
S-Turn's Avatar
Well, I have have no idea how familiar with cars you are, so I'll start with the basic suggestions. If you feel like it's missing check all of the plug wires and make sure the boots are tight on the plug. With some cars i've driven the air cleaner was so dirty that the car actually felt like it was lagging real bad, so mayble checking the air filter isn't a bad idea. My last suggestion is to double check the vacuum hoses since the car will run like crap if these aren't connected. There's many other possibilities, but i hope this helps![img]smileys/smiley1.gif[/img]
Old Dec 7, 2006 | 04:28 AM
High idle on S car engines is most often attributible to either a bad ECTS + connector (Engine coolant temp sensor), a vacuum leak, or just a filthy sticking throttle body.
Start with throttle body cleaning. When done, spray throttle body cleaner around all vacuum connections, and especially at the the intake manifold gasket and the throttle body connection. If rpms change, you've found your leak.
If problem persists, I would replace ECTS and connector (connector is Saturn only part).
Keep us posted
Derf
Edited by: derf
Old Apr 22, 2007 | 09:47 PM
Keep us posted
Derf
Thats the ticket.
mjulia31
Oct 13, 2008 05:08 PM
soxman
Apr 12, 2008 03:13 PM
redcannon
Jun 10, 2007 04:11 PM
elnino
Jun 5, 2007 09:01 PM
barristo
Aug 18, 2005 11:46 AM
