2003 L200 Odometer and Coolant level warning light
Old Oct 21, 2022 | 10:10 AM
Diane's Avatar
Default 2003 L200 Odometer and Coolant level warning light
Recently I had the water pump on my 2003 L200 replaced. However, I am still losing coolant just not as quickly. The car does NOT overheat. While going thru this the hood latch cable broke and I had it replaced. When I got it back the odometer backlight and the coolant level warning light are not working.. I do have an appointment next week with the mechanic. Just thought I would mention it here to see if maybe it’s a fuse or something simple. Thanks so much!
Old Oct 21, 2022 | 09:35 PM
The odometer backlight is a replaceable led only available at the dealer. The low coolant light is triggered by the BCM and those are soldered in led lights. I wonder if the garage left the sensor disconnected while replacing the water pump?
baming
Sep 1, 2015 10:52 PM
Joebeeker
Aug 29, 2013 05:30 PM
TonyT
Jun 29, 2008 08:46 PM
ljimmy43
May 31, 2007 12:21 AM
ray3483
Mar 15, 2006 12:03 PM
