2000 LS2 crank case ventilation
Old Dec 15, 2024 | 11:59 AM
chas9496's Avatar
Default 2000 LS2 crank case ventilation
I'm a former member of Saturn Fans since 2015 when I purchased my first Saturn. Just for forum reference. I have a 2000 LS2 with the 3.0. I found oil in the intake tubes changing the plugs, that wasn't there the last time I had them off. What I got online states that the PCV system may be clogged and forcing oil into the tubes. I also noticed one cylinder with oil that leaked down onto the plug on bank one. Valve cover gasket was another possible issue. Without disassembling of the intake and valve cover, is there any way to check for clogged ventilation ? There were some suggestions online, but I usually get my information thru the forum. I just don't want to go thru all that mess just to check the PCV reed valve for any malfunction, supposedly mounted in the rear cover. Thanks for any info.
Old Dec 15, 2024 | 05:56 PM
grcauto8453's Avatar
Home >> Saturn >> 2000 >> LS2 V6-3.0L VIN R >> Repair and Diagnosis >> Powertrain Management >> Emission Control Systems >> Positive Crankcase Ventilation >> Testing and Inspection >> Initial Inspection and Diagnostic Overview >> Functional Check
Functional Check
If engine is idling rough, check for a clogged PCV system. Check for leaks in the PCV system. Replace as required.
Use the following procedures to determine if the PCV system is functioning properly:
1. Remove PCV hose from cam vent housing.
2. Run engine at idle.
3. Place your thumb over ind of vent housing hose to check for strong vacuum signal. If vacuum is not present, check for a plugged intake manifold port. Replace any clogged components or clean out plugged port.
Old Dec 15, 2024 | 06:10 PM
chas9496's Avatar
Functional Check
:Thanks. I'll try that. I just moved and have to find my shop book. That would probably help, some. Not everything is shown there.
Old Dec 15, 2024 | 06:12 PM
Click in the breadcrumbs at the top. The entire manual is in there. Click away.
RjAquaponics
Saturn L300
40
Jun 11, 2020 10:28 AM
rth
Dec 16, 2017 09:37 PM
JohninPhoenix
May 30, 2013 08:07 AM
winkler91
Jul 26, 2011 12:30 PM
just1oldman
Feb 17, 2011 10:06 PM
