-   Saturn L Series Sedans & Wagons (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/)
-   -   2000 ls sedan (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/2000-ls-sedan-6941/)
jhernandez Jul 21, 2012 08:22 PM
2000 ls sedan
I have a 2000 ls and having a/c trouble. A/C was working fine last night and today would not come on. I checked relays, fuses, freon, all good, electrical power is good to compressor. The clutch is free but not spinning. Is this a compressor problem or a clutch problem? Thanx
sw2cam Jul 21, 2012 08:30 PM
If it's A/C: The first thing you need to do when working an an A/C unit is to put a set of gauges on it. Your welcome.
I'll ask one question..............does the heater and blower motor operate?
jhernandez Jul 21, 2012 11:23 PM
2000 ls sedan
Yes the heater and blower work fine. thnx for the reply
derf Jul 22, 2012 08:54 AM
is the clutch getting the signal via the relay to engage?
jhernandez Jul 22, 2012 09:22 AM
2000 ls
Yes I also switched relays and re;ays are fine
OceanArcher Jul 22, 2012 10:30 AM
Take a heavy gauge wire, and hook to the positive (+) side of the battery. Start the engine, and carefully touch the wire to the clutch control wire on the compressor. Does the clutch engage, and turn the compressor ??
RjION Jul 22, 2012 06:31 PM
2 Attachment(s)
Gauges high and low set
jhernandez Jul 22, 2012 06:53 PM
Tried jump wire and clutch did not engage, also no power to pressure sensor?
thanx for the info I guess I really have to get me a set of guages!!
OceanArcher Jul 23, 2012 04:37 PM
AutoZone will rent you a set of gauges.
Direct voltage to the clutch control wire should cause the clutch to engage
