2000 L200 bcm replacement questions
Old Jul 27, 2017 | 11:18 AM
Mikey702's Avatar
Default 2000 L200 bcm replacement questions
Can I install one of the used Modules as long as the numbers match up?
Will that mean that my odometer will show what the other car was reading?
Do I need to program anything? A couple of the sites said that the security light would still be on and another said that the keyless entry would not work.
Is this a good idea? Can I really mess something up? Any help would be appreciated.
Old Jul 27, 2017 | 02:03 PM
I have switched bcms before as a test.
The odometer reading is stored in the bcm.
You will have to do a 30 minute key on learn for the security system.
The key fob is also a bcm function.
What problems are you having with your bcm?
Old Jul 28, 2017 | 08:40 AM
There is also a BCM re-learn procedure that syncs the replacement BCM with your existing PCM.
Indeed, what has led to your condemnation of the BCM?
Old Aug 4, 2017 | 11:46 AM
jamnar's Avatar
cue the crickets.....
Old Jun 30, 2018 | 10:49 PM
Rebel's Avatar
Default Re-learn
What is the re-learn procedure for the bcm
Grbenda
Dec 30, 2019 03:05 AM
Noel Eldridge
Aug 2, 2019 07:53 AM
FRUGALSENIOR
Feb 16, 2019 02:13 PM
Mercurytech
Apr 27, 2018 04:58 PM
Surreality66
Feb 9, 2018 04:41 AM
