2000 L200 bcm replacement questions
Can I install one of the used Modules as long as the numbers match up?
Will that mean that my odometer will show what the other car was reading? Do I need to program anything? A couple of the sites said that the security light would still be on and another said that the keyless entry would not work. Is this a good idea? Can I really mess something up? Any help would be appreciated. |
I have switched bcms before as a test.
The odometer reading is stored in the bcm. You will have to do a 30 minute key on learn for the security system. The key fob is also a bcm function. What problems are you having with your bcm? |
There is also a BCM re-learn procedure that syncs the replacement BCM with your existing PCM.
Indeed, what has led to your condemnation of the BCM? |
cue the crickets.....
Re-learn
What is the re-learn procedure for the bcm
