2000 L200 bcm replacement questions
Can I install one of the used Modules as long as the numbers match up?
Will that mean that my odometer will show what the other car was reading?
Do I need to program anything? A couple of the sites said that the security light would still be on and another said that the keyless entry would not work.
Is this a good idea? Can I really mess something up? Any help would be appreciated.
I have switched bcms before as a test.
The odometer reading is stored in the bcm.
You will have to do a 30 minute key on learn for the security system.
The key fob is also a bcm function.
What problems are you having with your bcm?
Noel Eldridge
Aug 2, 2019 07:53 AM
FRUGALSENIOR
Feb 16, 2019 02:13 PM
