Transmission won't shift into 4th gear after throttle body reduced power
Old Jan 24, 2025 | 08:55 PM
Mortikai's Avatar
Default Transmission won't shift into 4th gear after throttle body reduced power
2007 saturn ion 2.2L
Car went into reduced power limp mode. Car also would not shift into 4th gear. Tried cleaning the connector in the driver's side kick panel but that didn't help. Throttle body was replaced and programed by mechanic and works now with no codes but the car still won't shift into 4th gear. Tried a flush and filter on the transmission and still nothing. Scan of transmission shows everything working as it should. Mechanics suggestion is transmission rebuild for $3800. Hoping I can find an answer here before sending it to the scrap heap.
Old Jan 25, 2025 | 04:16 AM
No pending codes?
Maybe still partly in limp mode. Does limp mode in this vehicle by definition include not allowing shifting into fourth gear?
ttec4u
Apr 15, 2022 12:31 PM
wotring80
Feb 8, 2020 01:15 AM
lukesteeler89
Jul 22, 2013 01:57 PM
Bmick68
Jan 18, 2009 10:14 PM
hkn royalt
May 15, 2008 11:51 PM
