starter spins the second i hook up battery
Old Jun 8, 2026 | 12:28 PM
Hardrock74's Avatar
Default starter spins the second i hook up battery
just replaced starter please help
Old Jun 8, 2026 | 06:54 PM
Did you disconnect any wiring from the starter when replacing the battery?
Sounds like the positive lead from the battery is now directly connected to the motor terminal of the starter instead of the switched terminal controlled by the signal wire coming from the ignition.
Old Jun 8, 2026 | 07:15 PM
Wire three and wire four are touching. Wire four is battery + and wire three is start signal from the key. Don’t forget to connect wire three to the same post as wire four per this diagram.
Old Yesterday | 09:46 AM
oldmarine's Avatar
I think you mean wire four and wire five, Andy, per the diagram.
Old Yesterday | 10:32 AM
Thanks!
Stove
Nov 19, 2024 08:00 AM
yaazh
Saturn Aura
20
Oct 3, 2024 10:27 AM
mheckler
Sep 6, 2015 01:59 AM
cb1987
May 25, 2010 05:19 PM
mkpatrick
Sep 9, 2007 11:22 PM
