Slight Water Problem
Old Jul 31, 2009 | 07:56 PM
Saturntuner88's Avatar
Default Slight Water Problem
I have a 2006 Ion quad coupe that is leaking water into the passanger side when the A/C is on the foot setting and slightly leaks on other settings but when its on FOOT the higher i set the speed the faster the water drips. It looks like it may be leaking from the blower motor and hitting the floor close to the center of the dash. Any one have an suggestions on what it might be ? i did try to blow out the drain with my blow gun but it sounded clean and clear.
Old Jul 31, 2009 | 09:09 PM
what the hell is a blow gun? is that like a blow fish?
Old Jul 31, 2009 | 10:55 PM
You need to BlowHard.
Old Aug 1, 2009 | 05:11 AM
sounds like the evaporator condensate (being water) is, by nature of its high surface tension, taking a path less traveled --- and that is making all the difference
Jobolt
Jul 14, 2015 01:26 AM
jisham
Dec 12, 2006 12:14 AM
cbaa1970
Apr 14, 2006 01:09 PM
capearbor
Oct 10, 2005 09:00 AM
starless127
Jun 16, 2005 02:40 PM
