-   -   Saturn ion 2 won't start (https://www.saturnforum.com/forum/saturn-ion-22/saturn-ion-2-wont-start-11484/)
02 LW300 Oct 14, 2018 11:06 PM
Do you have a code reader that gives live data? A reader that gives data will show rpm while cranking indicating the crank sensor is working. The one I bought was about $85.00, my Snapon red brick will not work on my can 06 Lincoln Navigator. These are strictly OBDII readers not manufacturer specific code readers. I can read live data and codes with the reader I bought from Napa.
dadinda Oct 15, 2018 06:53 AM
Ok Thanks. Back to work. Will try to change the CPS this weekend and get back to you.
dadinda Nov 3, 2018 01:42 PM
Hello again,
Been busy. Finally got time to work on the Saturn. Got a new ignition switch and installed it. Nothing at all. No crank no start no passlock blinking nothing. Reinstalled the old part and we have crank again but still no start.
19bonestock88 Nov 3, 2018 03:16 PM
Have you checked the crank position sensor? Without it your engine won’t start
dadinda Nov 3, 2018 04:02 PM
No. That is nexts
dadinda Nov 4, 2018 04:21 PM
Finally got it. A while back we had a miss. The code said CPS. We changed it but no go. It ultimately was the ICM but in the process of changing the CPS I broke off the keeper on the connector and it worked its way off. No CPS no start. Reconnected it and wrapped it with electrical tape. Hope it holds.
Thanks for the help.
Rubehayseed Nov 5, 2018 06:33 AM
Any way to use a zip tie on that connector? Much more secure than electrical tape.
19bonestock88 Nov 6, 2018 08:05 AM
I agree there, if you don’t get a zip tie or something mechanical on there to hold the connector, you’ll be left with a no start condition again at some point, likely at the most inopportune time...
ion03 Dec 24, 2018 01:13 PM
I had the same problem with my 03 ion. I took it to the dealer and they did two recalls on it. Ignition switch and infliction cylinder i think, and that fixed it.
dadinda Jan 18, 2019 05:00 PM
OK, 6 months later and no start again. Would the CPS pig tail coming lose but not completely off yet cause an engine miss fire condition?
