Paint code for door jamb paint
I'm in the process of restoring/modifying a 2004 Saturn Ion Redline ( The worst year of the car I know but there is sentimental value in this one) and I have a bit of rust in the door jam, under some of the interior panels and in the left rear of the trunk. I was wondering if anyone has found a paint match for the OEM blackish paint that is used on the interior chassis of these cars?
I agree, worst year. But also the most unique year. I am an 06 owner myself.
if i remember correctly there should be a sticker in the trunk with the paint code on it. Interior paint is the same as the exterior.
Believe the black was called onyx
Thanks gentlemen. I’ll giver a go with some GM 8555 black then.
I will definitely not be pegging the boost on the supercharger given that it just makes heat instead of horsepower if you run it too hard for too long. It has a gm stage 2 kit so it’s fun for now and if I get bored of it I will likely piece together a turbo kit from old SAAB parts, front mount intercooler and a better aftermarket turbo.
I’m in the assess and restore phase at the moment and so far I’m impressed for a 18 year old daily in the rust belt. There’s a bit of rust in the trunk and around clip holes inside and only a bit on the pinch welds under the car. All around pretty decent.
Yeah I’m cheaper than I am lazy. I have the whole interior stripped out of it doing a detail piece by piece trying to clean up the mess the passenger side drain made instead of throwing $150 at the the detailer to do it so I can get paid to do something I’m good at instead lol.
