P0301 Trouble shooting help
2004 Ion 2.2 litre Replaced Spark plugs, Ignition Coil Module, Fuel Injectors....runs great if rpms are above 1,000...when at idle there is a little mis here and there. Will throw a P0301 code every couple of days. I have put fuel additive to remove any water. Tried high octane gas and Lucas Fuel Treatment. Still same results. Any suggestions?
A (running compression test) I do have a compression tester! Start on 3 cylinders, or just check each one with all plugs out, so it cranks over easily and quickly?
Thanks in advance! 💯
PowerHouseCamaro
Nov 24, 2013 11:01 AM
sc1
Jan 22, 2013 01:59 PM
LightMedium
Saturn L300
14
Aug 29, 2010 09:36 AM
