No crank, no start and complete loss of power
Old Jan 11, 2025 | 06:57 PM
More_problems_than_time's Avatar
Default No crank, no start and complete loss of power
Hello,
Two big problems here for my 2005 Ion 2.2L.
1. Car would lose all power randomly when driving.
2. Currently has a no crank, no start. This has been happening on and off. Sometimes it starts fine, sometimes I have the no crank, no start.
I did some testing and the ignition switch seems good. I found that the powertrain relay is not pulling in. Relay measures fine with ohmmeter. There is 12v present to one side of the coil. I’m thinking a signal applies the ground to the other side of the coil which would pull it in and close the contact.
I can’t find what signal is sent to pull in that relay.
My assumption would be the ECU?
Could a bad ECU also cause the complete loss of power problem also?
Is the ECU and powertrain control module the same thing?
Thanks in advance.
Old Jan 11, 2025 | 08:06 PM
Don’t use a multimeter to diagnose non working circuits. Multimeters are designed to not load a circuit and cause damage to sensitive components. You have to load test relays. The main relay in Honda’s caused many problems in the 80s. Maybe Saturn used the same Bosch relay in your car.
Old Jan 11, 2025 | 08:11 PM
What is the main relay?
Where is it located?
Old Jan 11, 2025 | 09:24 PM
In your schematic it is labeled “powertrain relay”
Old Jan 12, 2025 | 12:16 AM
Oh ok.
Thanks for the info.
Old Jan 12, 2025 | 12:58 PM
grcauto8453's Avatar
Swap the relay with another.
Old Jan 12, 2025 | 01:31 PM
I did already, no change.
Thanks for the suggestion.
Old Jan 12, 2025 | 07:58 PM
Home >> Saturn >> 2005 >> ION L4-2.2L VIN F >> Repair and Diagnosis >> Starting and Charging >> Diagrams >> Electrical Diagrams
Electrical Diagrams
Starting And Charging Diagram 1:
Starting And Charging Diagram 2:
Old Jan 12, 2025 | 08:00 PM
You see the neutral switch and anything else that needs to be good in order for the relay to energize.
Old Jan 12, 2025 | 08:19 PM
I see now.
thanks for posting the schematics, very cool!
