Lost a part while driving!!
Old Feb 14, 2021 | 01:17 PM
Realfam's Avatar
Default Lost a part while driving!!
While i was driving on the freeway my car all of a sudden got REALLY LOUD so i pulled over amd popped the hood, there is a hole with threads right where the exhaust connects to the engine , and it's just blowing out hot air , what is supposed to go here? Plz help
Old Feb 14, 2021 | 03:08 PM
Front Oxygen sensor.
​​I bet the sensor is hanging off of the wiring harness by the connector. Those connectors usually require a firm tab press to disengage the connector.
You are looking for a sensor device similar to the picture below, dangling with the connector end connected to a matching connector.
Someone may have connected it to the connector, then installed it. This would have put many turns in The wire as it was threaded into place, creating a constant force to unthread it. If it wasn't completely tightened down, I suppose over time it could loosen. I don't see any evidence of it having broken off because there are no leftover threads in the hole at least not from this angle.
Old Feb 15, 2021 | 09:22 AM
100% agreement with derf. If that thing had been installed properly, it would have NEVER blown out! I've never seen that happen before.
Old Feb 15, 2021 | 01:09 PM
I had that happen to my work truck out of town. They get really loud!
Old Feb 15, 2021 | 01:37 PM
Realfam's Avatar
Ok so i found both 02 sensors and they are still connected and scewed in, i ended up getting a metal plug and plugging the hole.
Old Feb 15, 2021 | 07:42 PM
Hmmm
Could you take a few pictures from a different angle, not above? Whatever was there like we should be put back.
Old Feb 19, 2021 | 07:15 AM
Realfam's Avatar
K , so i when i had someone replace my catalytic converter they got one that was for a different year than my 05, that hole is where an oxygen sensor would have gone, instead of right up against the engine on the exhaust manifold
Old Feb 19, 2021 | 09:04 AM
As long as it runs good and isn't throwing any codes, I'd say mission accomplished!
02 LW300
Feb 2, 2021 07:47 PM
Sep 26, 2020 07:05 AM
CDCallahan
Jul 20, 2019 04:11 AM
budsjlm
Sep 16, 2009 03:22 PM
budsjlm
Sights N Sounds
Jul 28, 2009 06:45 PM
