Help 911 emergency. Help me
A shop did mine because I got in the car to go to work when it went out, so I didn't have time to mess with it.
But after thinking it though, it seems pretty simple. They were able to do it from the top.
well if I can replace a pre-bled master/slave combo with 5 rotating joints, there so you can maneuver it into place AND latch it to the firewall, then this should be easy.
Does Mandee need to worry about extraneous extra parts/ should she check under the hood for collateral damage? Would suck to get the part and find something else is needed
ah, pressure rises rises rises blammmmmmm
Mandee you probably want to check under the hood to see if there is any other damage.
Also, if someone with access to AllData could provide the R &R procedure to Mandee that would be mighty cool.
