gas tank removal
Old Feb 5, 2021 | 08:50 PM
Doug Shinnan's Avatar
Default gas tank removal
on saturn 2006 ION
Old Feb 5, 2021 | 11:03 PM
Is there a question in there? If you need to replace the fuel pump it most likely needs to come out. Pretty easy up on a hoist, not so easy on ramps on the ground.
Old Feb 5, 2021 | 11:55 PM
Please use your words.
As to the mounting straps. I don't remember the width but the answer is yes, they must be reinstalled AND fastened in order for the tank to reliably be held in place.
As for your question about the EVAP components mounted above the tank, yes, they are. I agree with you that it makes perfect sense to replace all of the fully functional EVAP components because you never know when one could fail, even on a newer car like the ion.
Regarding your very specific question regarding driving the vehicle without the gas tank attached, I don't recommend it as the fuel pressure at the rail will suffer and subpar performance may result.
Lastly, in response to your inquiry regarding fastener type, size, and availability, the answer is yes.
Perry Rose
Dec 5, 2020 09:21 AM
Kaseykurz
Jun 27, 2020 05:50 PM
jaf
Jun 26, 2018 11:49 PM
drackett
Jan 2, 2010 07:18 PM
phantomschic3
Jun 20, 2008 10:22 AM
