Clutch pedal fix
Old Aug 7, 2019 | 02:47 PM
19bonestock88's Avatar
Default Clutch pedal fix
Anyone who’s driven an aging Saturn Ion knows the woe of the broken clutch pedal... it comes up off the master cylinder rod and eventually the rod will punch through the backside of the pedal and you can’t properly disengage your clutch... here’s how I fixed my clutch pedal...
I bought a package of #10 machine screws (not sure what thread pitch)and nuts for like 97 cents, and drilled a 3/16” hole through the white clip that is on the clutch pedal, which unclips from the one side... removing the clip you can see the hole that the clutch rod can poke through (didn’t get a pic of that). I put two nuts on the machine screw up near the head and stuck it through the hole, secured it with a nut on the other side, like shown
This allows the screw to poke through the hole in the back of the pedal and contact the clutch rod directly, the screw (being metal) shouldn’t wear down against the rod like the plastic pedal did...
when installing the clip back on the pedal, you’ll notice that the clip, being attached on only one side, won’t hold still as you push the clutch pedal, you’ll need to run a sheet metal screw into the side of the pedal to secure the other side of the clip, and allow the clip to hold the pressure from the clutch rod...
Next, I made a pad about 1/4” thick from old useless wire that stops the pedal from overextending upward, not that it would come off the rod anyway, since the rod is no longer bottoming in the pedal, it’s contacting the machine screw...
Old Aug 7, 2019 | 02:57 PM
This pic is showing the installed clip on the pedal, and the sheet metal screw in the side of the pedal... in theory if you attached the nuts on the pedal side of the clip to the clip itself you could adjust the machine screw and thus, the clutch engagement point. I hadn’t thought to do that at the time of install, and I’m too lazy to tear it all apart again to modify my fix, but I may do that later on...
By the way, can this be stickied? Would hate to see it lost to time
Old Aug 8, 2019 | 03:25 AM
Nice job, bones.
Old Aug 8, 2019 | 07:45 AM
Awesome. I love the ingenuity of it!
Old Aug 8, 2019 | 08:48 PM
Bones -- do you have the part number for the white clip in case someone has a trashed one and wants to implement the fix?
What's the thread pitch on the screw and nuts? May make a difference later on w r t loosening.
Also -- please remove the reference to the store from where you acquired the supplies. They are an evil economic canker sore on the face of this country
Old Aug 9, 2019 | 11:24 AM
I don’t know the part number to that white clip...
Old Nov 25, 2019 | 04:44 PM
Beanlover's Avatar
Hey 19bonestock88, was just googling "saturn clutch pedal fix" and this was the first link...so congrats on that! lol
I am in the same position as you were. I have had my clutch master cylinder replaced because the ball on the rod broke off completely. Now the pedal is allowing the ball on the new master cylinder to poke through too far and it won't engage well at all (and I have leveled up my skill with driving a stick without a clutch).
My question is, how is your fix holding up now that it has been a couple of months since you did this? I like what you did and I'm ready to pull the trigger to make it happen but just wanted to see if your experience was good with it holding up under normal use this long.
Please let me know when you get a chance...thanks!
Bob
Old Nov 20, 2021 | 08:31 PM
mflores's Avatar
I recently bought a new bushing for the clutch push rod going to the pedal since the old one wore out and the clutch pedal lifted up. I replaced the bushing and drove it to work but half way thru the pedal popped put for the push rod any ideas on what I can do or if I missed something.
Old Jul 22, 2022 | 03:11 PM
rubyzpt's Avatar
thank you for this idea with the screw! I just tried it with minor fixes and works perfectly!
Old Apr 22, 2026 | 01:20 PM
argroupinc's Avatar
Default ^ swapping clutch pedal n master cylinder - bleeding
Hey Bob,
I'm sure you've resolve this by now.
I did everything but my wfes to-do list trying to fix my 250k pedal/ push rod set up.... many videos I made. Finally swapping the clutch pedal for new, w/ modifications + had to add a 'in the hole' rubber bushing due to push rod ball worn too much - which was also so worn I couldn't 'clip ' the ball in w/ the white retainer - so I had to also install a 'pedal retracting too far' mini vise grip down there.
QUESTION:
If you swapped the clutch master cylinder, where you able to get the bleeder hose retracted after clip removal by the housing up front?....
I've tried everything to get that to pull back and don't want to break anything.
clip removed but nylon hose won't slide back for bleeding
old
old
new
new
had to make some chop on new
Bob
03ion6491
May 13, 2017 04:08 PM
Jerm088
May 21, 2009 11:17 AM
MyfreeSC2
Jun 20, 2008 09:55 AM
nhughes18
Mar 6, 2008 10:45 PM
