charging problem on a 2004 ion
Old Apr 8, 2019 | 08:44 PM
Tana Carrillo's Avatar
Default charging problem on a 2004 ion
I am having problems keeping my car charged and I dont understand what is draining it but I have been keeping it on a battery charger at night just so I can drive it in town during the day then back on the charger at night.To start off let me tell you what started the whole thing: my starter went out so I replaced that and I also replaced the battery because mine was very old but the battery light has been staying on and draining the battery. So I buy a altenator and driveline belt thinking that the altenator was the problem but I had it checked and it is fine. So what can be draining my battery, we have been checking some fuse link and still have not found the problem. I have been going through this since Jan 10 I have just about pulled all my hair out and I dont think females look very good with no hair, can anyone help me please I need my car.
Old Apr 8, 2019 | 11:36 PM
On my L200 that has the same engine as your Ion the alternator main wire connects to the car at the starter. If your problems started when you had the starter replaced start looking there. Whoever installed the starter might have missed connecting all the power wires. It is easy to miss a wire when replacing a starter in our cars.
Old Apr 10, 2019 | 12:18 PM
Thank you Andy we will check it and if you can think of anything else please let me know, cause we are running out of ideas
Old Feb 5, 2022 | 04:50 PM
RobertT's Avatar
Default Same problem
If and when you figure this out please let me know. I am having the exact same problem and I even replaced the computer and still have the problem. Thanks and if I figure it out I will let you know.
Old Feb 5, 2022 | 06:09 PM
DropDead's Avatar
What all have you replaced?
it's a pretty simple set up.
1 connector to the alternator, 1 power wire from the alternator to starter. Then another power wire from starter to fuse box. That big post that sticks out. And thats met with the positive battery cable.
Old Feb 6, 2022 | 10:17 AM
They had connected the wire incorrectly at the starter. The wire between the b+ post on the starter and the b+ post on the alternator has a fusible link section. The fusible link will blow to save the alternator if you jump the battery backwards.
krispy261
Feb 24, 2025 09:35 PM
saturnvue04gal
Aug 20, 2017 08:47 PM
cb1987
May 25, 2010 05:19 PM
turbozeke418
Jan 26, 2009 09:57 PM
mkpatrick
Sep 9, 2007 11:22 PM
