Can I reuse an AC pressure switch washer (07 Saturn Ion-2 2.2)
Old Nov 22, 2024 | 02:26 PM
That1dude's Avatar
Default Can I reuse an AC pressure switch washer (07 Saturn Ion-2 2.2)
Im replacing the pressure switch, and there was a rubber washer wrapped around the threads where the new switch would go. It doesn't look worn or torn up. The new one didn't come with one so can I just reuse the old one?
Thanks
Old Nov 23, 2024 | 10:17 AM
grcauto8453's Avatar
To seal from leaks.
Old Nov 23, 2024 | 09:26 PM
DropDead's Avatar
Just go grab an o-ring kit from hobo freight.
Old Nov 24, 2024 | 05:11 PM
You'll want the correct one. They have to be AC friendly.
Old Nov 24, 2024 | 05:13 PM
That1dude's Avatar
Are you referring to the O-ring or the switch?
Old Nov 24, 2024 | 05:17 PM
The O-ring. Get a seal kit for your AC. A rubber seal will not last.
Old Nov 24, 2024 | 05:29 PM
That1dude's Avatar
But that's what was originally in there, a rubber seal, as pictured
Old Nov 24, 2024 | 06:05 PM
Unless you are a polymer chemist (which I actually am), "rubber" is used by folks as a generic name for all things that have the properties of what rubber things do.
There are o rings and other things made from rubber like compounds that have different chemical compositions which dictate their properties
The ones used in HVAC must not chemically react with the refrigerant or oil, and must be able to handle the pressures and temperatures in the system without shrinking, cracking, or otherwise self destructing.
So they make special o rings for HVAC, and the consensus is that you must use an o ring designed for this purpose.
Neither you nor I know from what material the previous one is made. So don't worry about the past
Concentrate on the future.
Old Nov 24, 2024 | 06:35 PM
That1dude's Avatar
You think it's safe to assume it's the type you described since it's stock? I'm the first and only owner of the car so i know it hasn't been changed.
Either way I looked at it again a bit closer and it has a small tear in it so I will definitely be replacing it now. Will keep in mind what you said
Thanks!
Old Nov 24, 2024 | 08:52 PM
I would indeed concur that the dude/dudette at the factory used the corect part.
Just make sure the o rings you purchase are listed for used in hvac, specifically R134a refrigerant
martrw
May 1, 2026 07:53 PM
dougonbay
Mar 5, 2022 07:02 AM
cadman33619
Sep 2, 2012 06:49 AM
mike82
Jul 12, 2011 09:01 AM
major
Jun 12, 2010 12:09 PM
