2007 Saturn Ion 2 Check Engine Light (2.2L Ecotec I-4)
Old Feb 20, 2025 | 09:54 PM
2007 Saturn Ion 2's Avatar
Default 2007 Saturn Ion 2 Check Engine Light (2.2L Ecotec I-4)
My 2007 Saturn Ion has a Check engine light, as far as I could hear, it sounded it really good still, and the oil is still full, the gas cap was closed and everything. I’ve heard that the Oxygen Sensor is a common issue, it seems minor as far as I can tell, so I’d appreciate some input on my check engine light, like I said, engine sounds great, gas cap is closed, plenty of clean oil, and nothing coming from the exhaust or a weird color.
(btw it has 75k Miles and has been well taken care of but still used,!which should say something)
Old Feb 20, 2025 | 10:33 PM
Go to AutoZone or similar and have them read the codes from the diagnostic port.
It's free.
Get a list of the codes and post them here using the format Pxxxx where xxxx is a 4-digit number.
Old Feb 21, 2025 | 04:20 PM
Got it scanned, said P0446, it said it was the EVAP. Still gonna get it fixed of course because I’m not trying to ruin the car, even if it might not entirely “cause” anything terrible, it’s cheap.
Old Feb 21, 2025 | 04:32 PM
grcauto8453's Avatar
If you don't have emissions testing let it go. It's not hurting your car at all.
Old Feb 21, 2025 | 05:15 PM
Luckily, my county in (Ohio) doesn’t do that
Old Feb 22, 2025 | 01:42 AM
Should you ever have issues where it becomes difficult to put gas in the tank, where the pump keeps clicking off immediately, you may need to address this. Otherwise, per Gary, it does no harm.
Old Feb 24, 2025 | 02:04 PM
fabricgator's Avatar
... it does no harm
BUT, now that you are used to driving around ignoring the MIL
What if another more serious code were to report?
You'd not have a clue until after the damage had been done or until you are awaiting the roadside hooker from the auto club.
So what that is, the EPA determined that gasoline evaporating from everyone's antique fuel tanks was ruining the planet. So they MANDATED that all new automobiles after a certain date must have a sealed fuel system and that the integrity of the ''sealed system" must self test and alert the driver by illuminating the ''' Money Light "'
What I propose is that once it is on, several others could stack behind it, some maybe potentially serious, and granny will never know because her know it all grandson told her to "Just ignore it, trust me"
Old Feb 24, 2025 | 05:51 PM
The clue might be that the engine is not up to snuff. That light will not save his engine. If there's that kind of damage it will show up in performance.
Old Feb 28, 2025 | 10:03 AM
Default I do have plans to fix it
However, I’ve got a few questions…
-How Difficult is it to fix?
-How Expensive
-What do I need to fix?
Old Feb 28, 2025 | 10:31 AM
Home >> Saturn >> 2007 >> ION L4-2.2L >> Repair and Diagnosis >> Powertrain Management >> Emission Control Systems >> Evaporative Emissions System >> Evaporative Emission Control Canister >> Canister Vent Valve >> Service and Repair
Canister Vent Valve: Service and Repair
Vehicle Lifting.
Evaporative Emission Canister Vent Solenoid Valve Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Disconnect the evaporative emission (EVAP) canister harness electrical connector (2) from the EVAP vent solenoid valve.
3. Clean away any debris that may be present around the EVAP canister vent solenoid valve.
4. Remove the EVAP canister bolt.
5. Lower the EVAP canister.
6. Rotate the EVAP canister vent solenoid valve counterclockwise in order to release it from the locked position.
7. Remove the EVAP canister vent solenoid valve from the canister.
Installation Procedure
1. Install the EVAP canister vent solenoid valve into the EVAP canister, with the valve aligned to the released position.
2. Rotate EVAP canister vent solenoid valve clockwise in order to secure it into the locked position.
Notice: Refer to Fastener Notice.
3. Install the EVAP canister and bolt.
Tighten the bolt to 10 N.m (89 lb in).
4. Connect the EVAP canister harness electrical connector (2) to the vent solenoid valve.
5. Lower the vehicle.
bucknbass
May 23, 2025 09:10 PM
nikki234
Jun 14, 2024 05:57 PM
tazassape
Dec 31, 2014 12:04 PM
crimsonandblue
May 5, 2013 08:40 PM
97SL2
Aug 18, 2009 08:04 PM
