2004 Ion 2 Quad Coupe knocking noise
Old 08-16-2017, 08:22 AM
Jpeterson's Avatar
Default 2004 Ion 2 Quad Coupe knocking noise
I have a 2004 ion2 coupe with the 2.2L Ecoteck. Just this morning it started a knocking noise, best I can tell, in the front. It only does it between 15 and 25 MPH. And only when my foot is off the gas. Goes away as soon as I press on the gas or when I slow down below 15 MPH any ideas? Thanks
Old 08-16-2017, 09:15 AM
First check for a loose wheel! Then I would run it in the air. Jacked up, rear wheels chocked, very secure or take it to a shop. May be an axle or a warped rotor making the caliper thump.
Old 08-17-2017, 02:13 AM
These cars seem prone to sway bar bushing end link failure.
Check thoise.
Old 08-17-2017, 12:06 PM
19bonestock88's Avatar
Check the upper strut mounts, the sway bar bushings, the end links... An oily coating on the strut body means it's broken and leaking its fluid...
tooter1
01-21-2017 03:52 PM
oleg_8831
04-22-2016 02:06 AM
05Ion3Quad
02-18-2016 10:04 PM
Digit4lPyro
02-27-2010 07:56 PM
Kenmtb
11-18-2006 08:48 AM
Quick Reply: 2004 Ion 2 Quad Coupe knocking noise
