Wont start right after filling up 07 aura xe
Old Aug 10, 2019 | 03:02 PM
Justalilbit's Avatar
Default Wont start right after filling up 07 aura xe
Hey everyone. I have two weird problems, not sure if its all electrical or what. My 2007 aura xe has been running fine, no stalls, no problems at all so far. However here the past month or so after i fill the car up I can turn the key over in which it will attempt to start. It will immediately shut off not completing the start up cycle( almost like it halfway starts) then when i restart it up it will keep starting itself even after i let the key go. Runs fine afterwards but doesnt sound good and quite embarrassing when im at a gas station. Any ideas? Oh and my license plate lamp is out although ive replaced the bulb. Definitely need an answer for that if somebody has one.
Old Aug 10, 2019 | 06:21 PM
Sounds like the fuel pump is starting to fail. I have Fords at work that have a timed crank cycle, it will crank until it starts or times out. Even if you let go of the key. You have to turn the key to off to get it to stop cranking. If the light and plate go up with the trunk lid there is probably a broken wire near the trunk hinge inside, the wires run down my driver's side hinge on my Saturn.
notny41
Jun 14, 2018 10:23 PM
nightwraith2002
Saturn Aura
24
Jul 29, 2016 07:00 PM
Keanl6
Saturn Aura
Jul 5, 2014 02:59 PM
SSim
Mar 3, 2011 09:42 PM
OH6A
Oct 4, 2007 07:55 PM
