Shifter Cable Part# 84523156 replacement
Old Mar 21, 2024 | 07:10 PM
KitCat15's Avatar
Default Shifter Cable Part# 84523156 replacement
HELP ME Please.
I can’t locate the part for my car as every one is out of stock. I’m being told it’s discontinued. What can I use as a substitute?
2009 aura xr 4 cylinder
Old Mar 21, 2024 | 08:14 PM
Please provide your vehicle information as in year, engine and if if is the light hybrid.
Old Mar 21, 2024 | 08:19 PM
KitCat15's Avatar
2009 Aura xr 4 cylinder
Old Mar 22, 2024 | 08:50 AM
I see where that cable is out of stock on Rock Auto for your car. With some research possibly a Malibu cable could be adapted. Have you tried a GM dealer search? The description is identical when you look at the “info” on both cables listed below. Might be worth a try.
Old Mar 22, 2024 | 09:07 AM
KitCat15's Avatar
All the local GM dealers for at least 50 miles are out of stock and are telling me the part has been discontinued. I tried ordering from gmpartsoverstock.com and the order was cancelled the next morning for the same reason. I even checked eBay and they’re out of stock as well. Unless I can find a repair kit for the busted one I have. I’ll definitely try the Malibu cable.
these are the measurements/details for each. In your opinion do you believe this will work?
Old Mar 22, 2024 | 09:32 PM
Which one is for your car? The top one is 3/4” longer overall. Longer is better. If your car needs the longer one you will need to see if you can loose 3/4” and make the shorter one work. It comes from the floor shifter to the top of the transmission which is on the driver’s side of the car.
Old Mar 22, 2024 | 09:45 PM
KitCat15's Avatar
Unfortunately mine would be the longer one. How would I get the cable to loosen up enough to fit?
Old Mar 22, 2024 | 10:45 PM
The cables are a fixed length however if it can be routed to reach and loose 3/4” it would work. I cannot tell without looking at the project. It is possible that it could work. Can you take a picture of the cable routing on your car?
Old Mar 22, 2024 | 11:17 PM
If it keeps popping off the ball, there are repair kits available on Amazon and ebay.
Johnnyt86
May 9, 2017 09:21 PM
marka
May 28, 2015 01:25 AM
sl bill
Jun 26, 2011 08:01 PM
Jul 29, 2009 08:12 PM
Rick51
Jun 3, 2008 04:45 PM
